According to the datasheet, it is recommended that the maximum value of the HO gate resistor should be 10 ohms as it can affect the adaptive gate drive if this value is too high. Would you be able to explain what would happen if a 22 ohm resistor was used? What issues would you expect?
Kind regards,
Kar
