General Enquiry on Power Regulator
Just for my curiosity.
1. Does TI have a power regulator chip that has both Switching(DCDC) and LDO regulator built-in?
2. AND it can automatically switch between DCDC and LDO based on the current consumption of a single load.
  • Hi David,
    I assume you are looking into buck regulators, where the input voltage is always higher than the output voltage? If so, I will assign this question to the buck team.
    As far as I know, there are certainly buck converters with an integrated LDO, but not sure about the automatic switchover depending on the load current.
    Milos
  • Hi David,
    We haven’t heard back so we're assuming this answers your question. If not, just post a reply below, or create a new thread if the thread has locked due to time-out.
    Thanks and regards,
    Milos
