Hi team,
About the enable control, is there any restriction about retring the device by EN signal? (EN : ON -> OFF -> ON)
Saito
Hi team,
Saito
Hi Milos-san,
Thanks. It's clear now. They just want to use EN to turn on and off the device. Competitor's custom device has some EN on/off timing restriction.
So, they just concerned if this device also has such a restriction.
Saito
Hi Saito,
There is a start-up delay time from EN = High until the device starts switching, which is typically 70 μs. If you have a specific sequence for the EN pin that needs to be tested, please let us know and we can check it.
Milos
