Can I use the TPS62745 to generate a negative rail while retaining very low Iq...?
i.e. As in the normal topology:
1. Input rail is +5volt.
2. Set the voltage selection to 2.1volts
3. Tie the output to 0V
4. Use verything that was conventionally tied to ground as the negative output rail. Output rail will be -2.1volts...?
