Other Parts Discussed in Thread: BQEVSW, BQ40Z50
So far, I've been dealing with registers in GG file and Data Flash section at BQEVSW.
Now, I'm trying to generate a DFI file for mass production.
I got to know most of the registers in the GG file and what they affects, now that I'm trying to generate a DFI file and I can't link the questions at Configure section at BQEASY with their effects on the registers in Data flash/GG file. Mostly in the 2B and 2C section. So, if there is a file or a guide that I can read there about what each question in bqEASY affects it will help me.
Also, when I fill in the questions in the Configure section I know how to control over the OC (1st Tier) Dsg and the OC (2nd Tier) Dsg.
But I can't figure out what question there or how I can control OC (1st Tier) Chg and OC (2nd Tier) Chg without manually changing Data Flash or GG file.
Also, I understand that some settings in Data Flash can be changed before you generate the DFI file, the question is at which part of the DFI generating?
I mean, Is it possible to make changes to Data Flash before completing the full BQEASY process or at any stage after battery production can you change a setting in Data Flash and export a DFI file?
Thanks alot for the helpers.
