LM5060-Q1: LM5060 Reverse Polarity Protection
Part Number: LM5060-Q1
Hi Team,
For LM5060-Q1 datasheet Figure 39(Application with Reverse Polarity Protection with Diodes for OUT Pin Protection), UVLO/OVP will be on negative voltage when there is reverse polarity power. That will violate the abs rating(-0.3V). Will that damage the IC?
To prevent a slow turn off in fault conditions, D5 is added to bypass the current limiting resistor R1.(words in datasheet below Figure 39)
The D5 here should be D4, right?
