I am looking for a design that can replace a mains power fuse.
We have tried many of the breaker switches on the market and that is not working for us.
This would need to be powered by the 115VAC/230VAC side, so I'm not exactly sure how this will work...
I am thinking a high-side current-sense resistor where the voltage is measured by an amplifier. Once the voltage (current) hits a set level an output goes high which can open up a mechanical relay.
The current-sense amplifier would need some type of isolation technology. Use a AC-DC convertor to power the amplifier...
I am wondering if someone out there may have already done this? Is there a package/design already available that can handle at least some of what is needed?
Thanks!
Scott
