Hi everyone.
I will make a PCB using TLC59208F to control directly N-FET without any IC buffer, my load is only control Led.
So It will run normal or not?
Thanks for your answer.
Hi everyone.
Hi Hardy Wu
i have confused with you advice,
You said that " When output channels open, voltage of gate would be pulled down. " that mean: Gate of P-FET should pulled down, but P-FET active when Gate pulled down so i think we must pulled up gate of P-FET.
could you give me some name of the P-FET it can saturation when TLC59208 active (in my design i had choose SI2307, is it ok)
Thanks you so much.
Hi Hoang,
Sorry that I may have some confusion words in the replay. What I said 'when output channels open' means turn-on the output channels. So the gate of P-FET would be pulled down and P-FET active, then turn on the LEDs.
