Other Parts Discussed in Thread: BQ27510-G2
I have tried multiple learning cycles but each time I fail to get the FC bit to set. I have verified that my CHEM ID is accurate through multiple runs.
What I have observed.
Following the 5 hour relax time from a discharge cycle, I begin my learning cycle by hitting IT_ENABLE. RUP_DIS clears and VOK/QEN are set.
I charge at a nominal rate of C/2. When my average current drops below the taper current, I see that the Voltage is above Charging_voltage - taper voltage. Capacity is still increasing at a slow rate. I believe I satisfy all the requirements where the FC bit should be set.
Please find attached my learning cycle for one of my runs. Any guidance would be appreciated. learningcycle.log
