Other Parts Discussed in Thread: LM2776,
I am also facing similar problem. I have tried to import LM317A_TRANS.LIB and LM2776_TRANS.LIB to TINA tool.
Manoj.R
Manoj.R
Hi Manoj,
Did you try importing the unencrypted model when using the new macro wizard? It won't work with the encrypted model.
I confirmed this works with the unencrypted LM317 model on the product folder. Below is a quick sim I threw together to check it was operating. .
Unfortunately I don't have access to the LM2776 model repository, so I'll reach out to the Low Voltage Switching Regulator group and have them respond here.
Hi Manoj,
The only model available for LM2776 is a PSpice model here: https://www.ti.com/product/LM2776/toolssoftware#model. You cannot directly import this into TINA.
As another option, there are some simulation options inside the Webench design/model for the LM2776.
