Fast charge current value which has been set by I2C is set default vale when WDT is expired.
Is there any way to keep the value set by I2C?
Best Regards, Taki
Best Regards, Taki
Taki,
To keep the device in host mode, the host has to reset the watchdog timer by writing 1 to WD_RST bit before the watchdog timer expires (WATCHDOG_FAULT bit is set), or disable watchdog timer by setting WATCHDOG bits REG05[5:4] = 00.
Ning.
