UCC21750: Connecting RST/EN line of multiple ICs
Part Number: UCC21750
Can i connect all 6 RST/EN lines ( using 6 drivers for a 3 phase inverter) so that i can  use a single microcontroller output pin to reset/enable all together.
  • Hi David,
    Yes, you can implement a global RST/EN signal by connecting all of the inputs together.
    You should populate separate filtering capacitors at each chip's RST/EN pin close to the IC in case of noise. This could be minimum of 100pF.
    Audrey
