Other Parts Discussed in Thread: TPS3813-Q1,
Hi team,
I would like to tie /RESET and /WD together to make MCU in reset state when either OV/UV or Watchdog time out error occurs.
Is there any concern using these functions tie together?
If this is possible, pull up resister values should be same as I use these pins separately, since /WD is in high impedance while /RESET is low, correct?
regards,
