TPS65295: TPS65295 Bootstrap for 2.5V output
Part Number: TPS65295
I am using TPS65295 IC for our DDR4 power solution. I have some queries.
  • Does bootstrap connection required for SW_VPP(2.5V generation) pin? (In pin description its mentioned “VPP switching node connection to the inductor and bootstrap capacitor” but there is no separate bootstrap pin and also in application design, no bootstrap connection is there).
Can you clarify the same?
