Hi Sir,
My customer recently encountered a problem with TPS2001D. After doing pulse output short test, it get burned and damaged.
May refer to the waveform below. The output peak current is up to 60A while the limited current is around 10A.
This damaged TPS2001D each time after replacing burned one with new one.
This waveform is quite different to what datasheet captures in the figure below left.
They would like to know
(1) What may cause TPS2001D damaged after pulse short output test?
(2) The measurement point of output current in datasheet is at pink circle or red circle in the figure below right?
Edward
