TPS22912C: Land pattern
Part Number: TPS22912C
Would you tell me the information of land pattern and solder mask for TPS22912CYZVR ?
There are no information on the datasheet.
Datasheet: TPS22912C
    Welcome to E2E!
    I am currently looking for a land pattern example that can be used for the TPS22912C. I will post the information as soon as I receive it.
    Andy Robles
    I was able to find a similar package, but in order to confirm if we can use the same land pattern I had to request some information that will take 2-3 days to get the data. I will get back to you as soon as I get the information.
    In the mean time I would like to promote on of our newer devices, the TPS22916C, which is very similar to the TPS22912C.
    The TPS22916C has a lower current consumption than the TPS22912C and offers an internal smart-on pin pull down resistor feature making an external pull down resistor necessary on the on-pin, which will reduce the BOM of the switching solution.
    In addition the TPS22916C has a similar RON values and similar rise time to support high capacitive loads.
    Let me know what you think.
    Andy Robles
    For the TPS22912C you may use the landing pattern found on the datasheet of the TPS22908.
    Let me know if you have any questions!
    Andy Robles
  • Andy-san,
    Thank you for your information.
    I use the landing pattern on TPS22908 dataheet.
    Takashi Murakami
