Part Number: BQ78350-R2-DEVICE-FW
Hi TIer,
Could you help us to provide document relate about select Common-Drain MOSFET mothed?
example SiHG018N60E and IPP60R022S7, which one suitable pair bq78350-r2? Need to focuse which parameter parts?
Hi TIer,
Are you looking for a MOSFET for the VEN pin circuit? The purpose of this circuit is to only turn on the resistor divider while measuring the voltage to reduce power consumption. The choice of MOSFET is not critical, you need to make sure it meets your application voltage requirements.
Matt
