Other Parts Discussed in Thread: UCC39002, , UCC29002
HI sir
pls See attached file
The V1 sense point connection for ucc28950 and ucc39002 is right?
Hello User6004348
It depends on what you are trying to do - are the UCC28950 and UCC29002 part of the same circuit ? Do they share the same ground potential ?
The +V1Sense connection to the UCC28950 is probably correct - it depends on whether V1 is the output voltage or not.
I don't know what -V1 sense is -
The ADJ pin of the UCC29002 should go to a small resistor in the sense line of the module being controlled - this is shown in the data sheet.
How many modules are you planning to connect together in the current sharing system ?
If you can send me your complete schematic - or schematics I can give you a better answer. If you dont'w want to post it here you can send it to me directly at
colingillmor@ti.com
Colin
Hi
Thanks for sending me your schematic. Your connections for the UCC28950 and UCC29002 are correct. I've emailed you some suggestions for a more accurate output voltage sensing.
I'll leave this thread open for a few more days -
Colin
