I'm looking for Led-backlight Driver to be used in a new design and LP8863-Q1 may be a good option. I would like to use an analog signal to control the dimming of the leds.
Will be possible to do it using the LP8863-Q1 on PIN SDO-PWM? I know that some chips that use PWM for control dimming implement a LPF on PWM input to generate an analog voltage but I don't know if this is the case of the LP8863-Q1. If this is not the case, could you please advice other TI chip that may be used in that way?
Best regards and thanks in advance
Diego
