Hi, Can you please advise what RGB LED can be used with the LP5569. My understanding is that a 6 leg LED will be required due to the 2 input power sources (red > VIN, Green/Blue > Lp5569 Charge pump). So it must be an LED without any common cathode/anode connections. A part number for a 5mm Through Hole RGB LED or how to configure this would be a great help. Thank you for taking the time to answer this question.
