BQ28Z610: Learning cycle for battery replacement?
Part Number: BQ28Z610
My product has a removable battery pack, and the bq28z610 is mounted on the application side. What should I do if I don't want to reprogram the golden file every time the battery is replaced? Can I instruct the customers to run a full discharge-relax-charge-relax-discharge-relax cycle after replacing the battery (Qmax would be capped by the Qmax delta I guess)? Or can I write some parameters (just the Qmax Cells and Qmax Pack are needed to change right?) to the bq28z610 data memory (customers can only replace with new batteries in this case)?
Thanks.
