Other Parts Discussed in Thread: DRA829
Hi all,
I am designing the J7 platform base on SOC:DRA829 and PMICA:TPS659413 and PMICB:TPS659411, we are designing the SOP products, there is something need your help:
1 What is the timing sequence between VCCA(3V3),nPWRON/ENABLE of PMICA and VOUT_LDOVINT of PMICA? since I think the input signal nPWRON/ENABLE will be behind the output signal VOUT_LDOVINT which will ensure the synchronization of PMICA and PMICB, can you provide me with the exactly number of the time sequency?
2 According to TI reference design: J7 EVM board, only PMICA have the wakeup function from GPIO4, and PMICB will follow the standard startup sequence process(like high level input signal on nPWRON/ENABLE) , my quension is that in real SOP product is the PMICB in this design can will be wakeup from the LP_standby state?we need to meet the quiescent current requirement.
thanks!
