Part Number: LM5069
I am going to use this device as the application note suggested, but the information is not clear about the reverse current.
During the reverse current the source voltage go higher than the gate (or enough to turn off the MOSFET).
So the reverse current will flow through the MOSFET body diode for a shorter period, until the drain voltage (Vin) equal (one diode drop less) to the source to turn on the MOSFET again.
Does it going to cause any issues.
Hot swap circuit in my application is situated between the motor and the load dump, the current flows in reverse direction when the motor in Regen mode.
Thank you
Siva
