Customer is looking for a load sharing solution in their DCDC brick module with 50V output. Could you please help check whether UCC39002 can support it? If not, is any other solution for them? Thank you.
Hello Aki Li.
The answer is yes . The UCC39002 can operate with 50V output power modules. This is described in the data sheet aand also in the attached document.
John
