Other Parts Discussed in Thread: TPS54240, , TPS2511
I utilized the TPS2511EVM-141 components and layout in a design with a BLE connected device and the Circuit is failing radio emissions testing due to EMI created by the switching regulator, TPS54240.
On the EVM board there is a flyback diode, D3. In other designs I have seen a snubber circuit utilized in parallel with this diode to minimize any ringing that may occour.
I would like to know if there are any recommendations for values of a capacitor and resistor series to go in parallel with D3 as a snubber circuit for use with the components and respective values in on the EVM board that will effectively reduce ringing on the output of the TPS54240 and minimize EMI.
See attached Data sheet, schematic on PG 4.
Thank youTPS2511EVM-141.userGuide.pdf
