Other Parts Discussed in Thread: TPS25921A
Hi Team,
My Customer created a set-up to test the current limit over temperature for TPS259241 and TPS25921A. Using TPS259241 and TPS25921A efuse's and the datasheet circuit configuration. The TPS259241 current limit, which is set to 2.5A, is varying a lot over temperature. While this behavior is not present with the TPS25921A
Can you explain why or make suggestions to improve this?
Renan
