Is it okay to just pull the DIA_EN pin high and still be able to use the diagnostic functions of the chip. We don't have enough pins left on our microcontroller and want to make sure the part will still work correctly if we do this. The data sheet says this pin is active high and as far as we can tell, it doesn't explicitly say that the part needs to see a transition from low to high on this signal. But we wanted to confirm this. Thank you.
