bq24030 solar charging - lower current limit
Other Parts Discussed in Thread: BQ24210
Normal 0 false false false MicrosoftInternetExplorer4
I am using this device for charging a Lithium battery from a solar panel and wanted to know what is the lowest amount of input current this device can handle.  I believe the solar panel will only provide 25ma.  Can some one recommend a solution if this device does not handle this low current, thank you.
