Hi Team,
Would you advise below three questions about IMON?
(Question)
1. Are you assuming an application in which an AD converter is externally connected to the IMON pin of the TPS24750 to detect the current value of the SENSE resistor? If possible, could you provide an application example?
2. I could not find the relational expression to derive the current value flowing in the SENSE resistor from the IMON terminal voltage value from the datasheet and other technical data. If you have any of the above application examples, would you kindly let me know?
3. Also, if I have an AD converter connected to the IMON pin and monitor the current value, please let me know if there are any points to be aware of.
Shidara
