Other Parts Discussed in Thread: TPS40210
Hello, I'm designing a boost converter similar to the one described in Typical Application 8.2 on page 26 of the datasheet for the TPS40210. I was going through the calculations and am having trouble with Equation 59. When I put this into MATLAB with the typical application numbers, I get 0.2087. I checked with a colleague and he also gets this. Can you verify that this calculation is correct?
https://www.ti.com/lit/ds/symlink/tps40211-q1.pdf?ts=1587768910081
Thanks!
