BQ40Z50-R2: Grounding Scheme; AGND/CHGND/GND
Part Number: BQ40Z50-R2
Other Parts Discussed in Thread: BQ40Z50
I am designing a power management module with the BQ40z50 IC and am trying to determine how to keep the specified grounds performing well. It seems that there are 3 main grounds; AGND, CHGND, and GND. I understand for CHGND and GND they should be kept separate and that together with PACK+; CHGND is essentially your PACK- reference.
However, for AGND, should this also be totally isolated from any board grounds and IC ground (GND and CHGND)? Or is there another way to connect this to your system, through a 0ohm resistor to GND for instance?
Chris
