Other Parts Discussed in Thread: TPS53515, TPS548A20
Could you tell me about TPS53319 OCP?
The following contents are described in the data sheet.
In case of “Duty> 45%” condition,
How much is the OCP accuracy degraded?
Customers are trying to use the TPS53319 under the following conditions.
Vin=5V, Vout=2.6V, (Duty:52%)
I announced the OCP issue to the customer based on the datasheet.
However, it is necessary to have information on how much the OCP accuracy will be reduced in order to correct the circuit.
Could you give me your advice?
Yusuke
