Other Parts Discussed in Thread: TLV759P, LM2990
Hi!
Can You explain definition some LDO parameters in datasheets? My ask about line and load regulation. Document SLVA079 (http://www.ti.com/lit/an/slva079/slva079.pdf) define description for line and load regulation. It is ratio of delta Vout to delta Vin (Iout). But in some datasheet parameters indicated in Volts (LM2990, in example), volts and V/A (TLV759P). How i can properly measure this parameters in my design and how i must understand parameters in datasheets? Can you recommend some standards for measure this parameters?
