BQ27421-G1: SOC jumps from 65% to 100%
Part Number: BQ27421-G1
At the end of a charging cycle with updates every minute, the fuel gauge SOC jumped directly from 65% to 100%.
I'm trying to understand why that happened, can anyone give me some insight?
Thank you
Please see attached charging log.
  • bq27xxx-battery 1-0055: design-capacity has 2000
    bq27xxx-battery 1-0055: design-energy has 7400
    bq27xxx-battery 1-0055: terminate-voltage has 3000
    bq27xxx-battery 1-0055: taper-rate has 136
    bq27xxx-battery 1-0055: Battery Capacity Change 5
    healthd: battery l=5 v=3772 t=20.3 h=1 st=2 c=782 fc=2234000 chg=u
    healthd: battery l=5 v=3778 t=21.4 h=1 st=2 c=798 fc=2234000 chg=ubq27xxx-battery 1-0055: Battery Capacity Change 6
    healthd: battery l=6 v=3838 t=26.1 h=1 st=2 c=968 fc=2234000 chg=u
    healthd: battery l=6 v=3843 t=27.8 h=1 st=2 c=944 fc=2234000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 7
    healthd: battery l=7 v=3846 t=28.9 h=1 st=2 c=945 fc=2234000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 8
    healthd: battery l=8 v=3831 t=29.9 h=1 st=2 c=833 fc=2234000 chg=u
    healthd: battery l=9 v=3650 t=30.9 h=1 st=2 c=-215 fc=2234000 chg=u
    healthd: battery l=11 v=3850 t=32.4 h=1 st=2 c=922 fc=2234000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 12
    healthd: battery l=12 v=3844 t=32.7 h=1 st=2 c=856 fc=2234000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 13
    healthd: battery l=13 v=3844 t=33.0 h=1 st=2 c=855 fc=2234000 chg=u
    healthd: battery l=13 v=3839 t=33.3 h=1 st=2 c=825 fc=2234000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 14
    healthd: battery l=14 v=3851 t=33.5 h=1 st=2 c=836 fc=2234000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 15
    healthd: battery l=15 v=3854 t=33.7 h=1 st=2 c=845 fc=2234000 chg=u
    healthd: battery l=15 v=3857 t=33.9 h=1 st=2 c=850 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 16
    healthd: battery l=16 v=3860 t=34.0 h=1 st=2 c=853 fc=2235000 chg=u
    healthd: battery l=16 v=3861 t=34.0 h=1 st=2 c=849 fc=2235000 chg=u
    healthd: battery l=16 v=3865 t=34.1 h=1 st=2 c=852 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 17
    healthd: battery l=17 v=3869 t=34.2 h=1 st=2 c=853 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 18
    healthd: battery l=18 v=3866 t=34.3 h=1 st=2 c=817 fc=2235000 chg=u
    healthd: battery l=18 v=3877 t=34.3 h=1 st=2 c=846 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 19
    healthd: battery l=19 v=3883 t=34.4 h=1 st=2 c=838 fc=2235000 chg=u
    healthd: battery l=20 v=3859 t=32.5 h=1 st=2 c=745 fc=2235000 chg=u
    healthd: battery l=20 v=3862 t=33.0 h=1 st=2 c=758 fc=2235000 chg=u
    healthd: battery l=20 v=3894 t=34.3 h=1 st=2 c=908 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 21
    healthd: battery l=21 v=3881 t=34.4 h=1 st=2 c=763 fc=2235000 chg=u
    healthd: battery l=21 v=3884 t=34.5 h=1 st=2 c=761 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 22
    healthd: battery l=22 v=3889 t=34.7 h=1 st=2 c=759 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 23
    healthd: battery l=23 v=3898 t=35.0 h=1 st=2 c=756 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 24
    healthd: battery l=24 v=3933 t=35.1 h=1 st=2 c=947 fc=2235000 chg=u
    healthd: battery l=24 v=3941 t=35.1 h=1 st=2 c=940 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 25
    healthd: battery l=25 v=3947 t=35.2 h=1 st=2 c=932 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 26
    healthd: battery l=26 v=3954 t=35.3 h=1 st=2 c=930 fc=2235000 chg=u
    healthd: battery l=26 v=3961 t=35.4 h=1 st=2 c=928 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 27
    healthd: battery l=27 v=3968 t=35.5 h=1 st=2 c=923 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 28
    healthd: battery l=28 v=3974 t=35.6 h=1 st=2 c=919 fc=2235000 chg=u
    healthd: battery l=28 v=3978 t=35.7 h=1 st=2 c=937 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 29
    healthd: battery l=29 v=3988 t=35.8 h=1 st=2 c=937 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 30
    healthd: battery l=30 v=3995 t=36.0 h=1 st=2 c=938 fc=2235000 chg=u
    healthd: battery l=30 v=4002 t=36.1 h=1 st=2 c=939 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 31
    healthd: battery l=31 v=4009 t=36.2 h=1 st=2 c=939 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 32
    healthd: battery l=32 v=4015 t=36.3 h=1 st=2 c=931 fc=2235000 chg=u
    healthd: battery l=32 v=4022 t=36.4 h=1 st=2 c=927 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 33
    healthd: battery l=33 v=4029 t=36.4 h=1 st=2 c=926 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 34
    healthd: battery l=34 v=4037 t=36.3 h=1 st=2 c=916 fc=2235000 chg=u
    healthd: battery l=34 v=4044 t=36.3 h=1 st=2 c=918 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 35
    healthd: battery l=35 v=4051 t=36.3 h=1 st=2 c=913 fc=2235000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 36
    healthd: battery l=36 v=4058 t=36.1 h=1 st=2 c=905 fc=2236000 chg=u
    healthd: battery l=36 v=4061 t=35.9 h=1 st=2 c=909 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 37
    healthd: battery l=37 v=4073 t=35.7 h=1 st=2 c=933 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 38
    healthd: battery l=38 v=4081 t=35.7 h=1 st=2 c=924 fc=2236000 chg=u
    healthd: battery l=38 v=4088 t=35.5 h=1 st=2 c=924 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 39
    healthd: battery l=39 v=4096 t=35.4 h=1 st=2 c=925 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 40
    healthd: battery l=40 v=4104 t=35.2 h=1 st=2 c=924 fc=2236000 chg=u
    healthd: battery l=40 v=4111 t=35.1 h=1 st=2 c=921 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 41
    healthd: battery l=41 v=4119 t=35.0 h=1 st=2 c=912 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 42
    healthd: battery l=42 v=4128 t=34.9 h=1 st=2 c=911 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 43
    healthd: battery l=43 v=4133 t=34.7 h=1 st=2 c=905 fc=2236000 chg=u
    healthd: battery l=43 v=4145 t=34.6 h=1 st=2 c=902 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 44
    healthd: battery l=44 v=4153 t=34.5 h=1 st=2 c=926 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 45
    healthd: battery l=45 v=4161 t=34.4 h=1 st=2 c=923 fc=2236000 chg=u
    healthd: battery l=45 v=4170 t=34.3 h=1 st=2 c=921 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 46
    healthd: battery l=46 v=4178 t=34.2 h=1 st=2 c=919 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 47
    healthd: battery l=47 v=4188 t=34.1 h=1 st=2 c=922 fc=2236000 chg=u
    healthd: battery l=47 v=4197 t=33.9 h=1 st=2 c=918 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 48
    healthd: battery l=48 v=4206 t=33.8 h=1 st=2 c=910 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 49
    healthd: battery l=49 v=4215 t=33.7 h=1 st=2 c=904 fc=2236000 chg=u
    healthd: battery l=49 v=4221 t=33.6 h=1 st=2 c=897 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 50
    healthd: battery l=50 v=4231 t=33.5 h=1 st=2 c=890 fc=2236000 chg=u
    healthd: battery l=50 v=4239 t=33.3 h=1 st=2 c=879 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 51
    healthd: battery l=51 v=4246 t=33.1 h=1 st=2 c=885 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 52
    healthd: battery l=52 v=4252 t=33.0 h=1 st=2 c=870 fc=2236000 chg=u
    healthd: battery l=52 v=4257 t=32.7 h=1 st=2 c=848 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 53
    healthd: battery l=53 v=4258 t=32.4 h=1 st=2 c=819 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 54
    healthd: battery l=54 v=4264 t=32.0 h=1 st=2 c=791 fc=2236000 chg=u
    healthd: battery l=54 v=4266 t=31.7 h=1 st=2 c=760 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 55
    healthd: battery l=55 v=4268 t=31.3 h=1 st=2 c=727 fc=2236000 chg=u
    healthd: battery l=55 v=4270 t=31.0 h=1 st=2 c=696 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 56
    healthd: battery l=56 v=4272 t=30.6 h=1 st=2 c=666 fc=2236000 chg=u
    healthd: battery l=56 v=4272 t=30.3 h=1 st=2 c=639 fc=2236000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 57
    healthd: battery l=57 v=4273 t=29.9 h=1 st=2 c=611 fc=2236000 chg=u
    healthd: battery l=57 v=4273 t=29.6 h=1 st=2 c=583 fc=2236000 chg=u
    wlcore: mac80211 set key
    bq27xxx-battery 1-0055: Battery Capacity Change 58
    healthd: battery l=58 v=4275 t=29.3 h=1 st=2 c=557 fc=2236000 chg=u
    healthd: battery l=58 v=4275 t=28.9 h=1 st=2 c=533 fc=2236000 chg=u
    healthd: battery l=58 v=4276 t=28.6 h=1 st=2 c=509 fc=2237000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 59
    healthd: battery l=59 v=4277 t=28.3 h=1 st=2 c=486 fc=2237000 chg=u
    healthd: battery l=59 v=4277 t=28.1 h=1 st=2 c=465 fc=2237000 chg=u
    healthd: battery l=59 v=4278 t=27.9 h=1 st=2 c=446 fc=2237000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 60
    healthd: battery l=60 v=4278 t=27.7 h=1 st=2 c=427 fc=2237000 chg=u
    healthd: battery l=60 v=4279 t=27.6 h=1 st=2 c=409 fc=2237000 chg=u
    healthd: battery l=60 v=4278 t=27.6 h=1 st=2 c=393 fc=2237000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 61
    healthd: battery l=61 v=4279 t=27.5 h=1 st=2 c=377 fc=2237000 chg=u
    healthd: battery l=61 v=4280 t=27.5 h=1 st=2 c=363 fc=2237000 chg=u
    healthd: battery l=61 v=4280 t=27.5 h=1 st=2 c=350 fc=2237000 chg=u
    healthd: battery l=61 v=4280 t=27.8 h=1 st=2 c=336 fc=2237000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 62
    healthd: battery l=62 v=4281 t=27.8 h=1 st=2 c=325 fc=2237000 chg=u
    healthd: battery l=62 v=4280 t=27.8 h=1 st=2 c=313 fc=2237000 chg=u
    healthd: battery l=62 v=4281 t=27.7 h=1 st=2 c=302 fc=2237000 chg=u
    healthd: battery l=62 v=4282 t=27.8 h=1 st=2 c=291 fc=2237000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 63
    healthd: battery l=63 v=4282 t=27.8 h=1 st=2 c=281 fc=2237000 chg=u
    healthd: battery l=63 v=4282 t=27.8 h=1 st=2 c=271 fc=2237000 chg=u
    healthd: battery l=63 v=4282 t=27.8 h=1 st=2 c=260 fc=2237000 chg=u
    healthd: battery l=63 v=4282 t=27.8 h=1 st=2 c=251 fc=2237000 chg=u
    healthd: battery l=63 v=4283 t=27.7 h=1 st=2 c=241 fc=2237000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 64
    healthd: battery l=64 v=4283 t=27.7 h=1 st=2 c=231 fc=2237000 chg=u
    healthd: battery l=64 v=4283 t=27.6 h=1 st=2 c=223 fc=2237000 chg=u
    healthd: battery l=64 v=4283 t=27.5 h=1 st=2 c=214 fc=2237000 chg=u
    healthd: battery l=64 v=4283 t=27.4 h=1 st=2 c=205 fc=2237000 chg=u
    healthd: battery l=64 v=4284 t=27.3 h=1 st=2 c=197 fc=2237000 chg=u
    healthd: battery l=64 v=4284 t=27.2 h=1 st=2 c=188 fc=2237000 chg=u
    healthd: battery l=64 v=4284 t=27.0 h=1 st=2 c=181 fc=2237000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 65
    healthd: battery l=65 v=4284 t=26.9 h=1 st=2 c=173 fc=2237000 chg=u
    healthd: battery l=65 v=4285 t=26.8 h=1 st=2 c=166 fc=2237000 chg=u
    healthd: battery l=65 v=4285 t=26.7 h=1 st=2 c=159 fc=2237000 chg=u
    healthd: battery l=65 v=4285 t=26.6 h=1 st=2 c=153 fc=2237000 chg=u
    healthd: battery l=65 v=4285 t=26.5 h=1 st=2 c=146 fc=2237000 chg=u
    healthd: battery l=65 v=4285 t=26.4 h=1 st=2 c=140 fc=2237000 chg=u
    bq27xxx-battery 1-0055: Battery Capacity Change 100
    healthd: battery l=100 v=4285 t=26.2 h=1 st=2 c=135 fc=1449000 chg=u
    healthd: battery l=100 v=4285 t=26.1 h=1 st=2 c=129 fc=1451000 chg=u
    healthd: battery l=100 v=4285 t=26.0 h=1 st=2 c=124 fc=1453000 chg=u
    healthd: battery l=100 v=4285 t=25.9 h=1 st=2 c=119 fc=1455000 chg=u
    healthd: battery l=100 v=4286 t=25.8 h=1 st=2 c=115 fc=1457000 chg=u
    healthd: battery l=100 v=4286 t=25.7 h=1 st=2 c=111 fc=1459000 chg=u
    healthd: battery l=100 v=4262 t=25.3 h=1 st=5 c=0 fc=1459000 chg=u
    healthd: battery l=100 v=4259 t=25.1 h=1 st=5 c=0 fc=1459000 chg=u
    healthd: battery l=100 v=4257 t=24.9 h=1 st=5 c=0 fc=1459000 chg=u
    healthd: battery l=100 v=4255 t=24.8 h=1 st=5 c=0 fc=1459000 chg=u
    healthd: battery l=100 v=4254 t=24.7 h=1 st=5 c=0 fc=1459000 chg=u
    healthd: battery l=100 v=4252 t=24.6 h=1 st=5 c=0 fc=1459000 chg=u
    healthd: battery l=100 v=4251 t=24.5 h=1 st=5 c=0 fc=1459000 chg=u
    healthd: battery l=100 v=4250 t=24.5 h=1 st=5 c=0 fc=1459000 chg=u
    healthd: battery l=100 v=4249 t=24.4 h=1 st=5 c=0 fc=1459000 chg=u
  • Hi Peter,
    The gauge device has a lot of run-time information.  Without sufficient data, it is almost not possible to find the root cause. I don't use your log file for analysis.
    I would suggest you capture a bqStudio log and also share your gg file.  Thanks.
    Andy
