hello,
What is the difference between EN_HiZ setting enable and disable when battery is connected and VBUS is not connected?
For example, is there a difference in battery current consumption or VSYS output voltage?
best regards
hello,
best regards
HIZ refers to high impedance mode. When the device is in HIZ, REGN LDO is off, the device draws less than IVBUS_HIZ from VBUS. In HIZ mode, the battery powers up the system if battery is present. If the battery is not present, VSYS is 0V.
Ning.
