Team,
Is it possible to control two TPS54478 units on EN from one TPS54478's PGOOD? Wouldn't be the current from two enables to one power good too high? Can´t find the current or voltage flows from EN in datasheet.
Based on the below graph from datasheet (page 15), it seems it works without pull-up resistor on PGOOD.
And in pin specification, it is mentioned than there is some current source and pull up (page 4).
And in functional diagram, there could be seen some sources in EN.
