Hi, team,
I have some questions about Loss-of-GND protection of HS switch. Please share your insights.
1. Under what condition will HS switch Loss-of-GND protection be used? Because there is only HS MOSFET in HS switch, no LS MOSFET inside, no current will flow from external GND plane into device MOSFET.
2. For TPS4H160-Q1, "When loss of GND occurs, output is shut down regardless of whether the INx pin is high or low." I think since GND is for device internal power supply, removing GND will absolutely shutdown device, please correct me if wrong.
2. In TPS4H160-Q1 datasheet, "The device can protect against two ground-loss conditions, loss of device GND and loss of module GND." What is the difference of device GND and module GND?
Thanks.
Johnny
