Does such an IC exist? Where the parameters for the rest of the IC are similar except it natively supports flyback topology and has some kind of current sensing for a resistor in the primary switch current path?
Thanks.
Thanks.
Hi John,
TL494 can be used for flyback topology. A application note for your reference.
http://www.ti.com/lit/an/slva666/slva666.pdf?ts=1588816161331
Teng
Oh thanks I hadn't seen that before.
But there's definitely no similar IC available with the current sensing built in?
