I am working on a design which has an LM27951 LED backlight driver and low power sleep modes.
In normal operation, the LM27951 seems to operate OK; the backlight is illuminated consistently etc.
The problem I have is in low power sleep. I have pulled the LM27951 shutdown pin low and verified that the internal charge pump stops (with DMM and oscilloscope), so supply current should be <1uA per the datasheet. But the chip draws approximately 2900uA in this mode.
Any suggestions for what to do next?
