Hi All,
We are working on a Handheld battery-powered medical device that uses a 900mAh Li-Ion battery. We are using the TIs LM66100DCKR ideal diode for power or-ing between VBUS (5V USB Input) & VPACK (4.2V battery Voltage). We are feeding the output of the power or-ing circuit to the input of TIs Buck regulator TPS62821DLCR to generate 3V rail. We would like the design to be get reviewed by the TI team. Attached the snippet of the schematic implementation. Could you please review our design & provide your valuable review comments.
Thanks in advance!
Krishnaprabha
CC: @ Timothy Logan Could you please have a look at this. I found from several threads that you have helped many people with Power management ICs.
