BQ40Z50: bq40z50 IFC question
Part Number: BQ40Z50
Hi Team,
Could you please explain what can cause our gas gauge report IFC PF =1?
I see the TRM explain: The device can permanently disable the battery if it detects a difference between the stored IF checksum and the calculated IF checksum only following a device reset.
But could you please explain what operation will cause the difference between the stored IF checksum?
Thanks!
Eason,BR
  • Hi Eason,
    As fas as I know, the cause of the IFC PF is most likely that the instruction flash is corrupted.  I suggest you dumped a srec file and compare its instruction flash with the instruction flash of a default srec file.
    Andy
