Hi Sir,
May I learn from you if FB pin lower divide resistor short to GND, will TPS56628 trigger OVP?
If yes, may I know how the TPS56628 sense the voltage above 125%?
If not, may I know what behavior will TPS56628 do?
Thank you.
Edward Chen
Hi Sir,
Thank you.
Edward Chen
If lower FB resistor is short to GND, IC will trigger UV protection after soft-start end.
Yuchang
