Other Parts Discussed in Thread: LP5569
Hi Ankita,
Sorry there is no solution to change reset behavior and default value, and all of our RGB LED drivers need I2C commands to be illuminated.
LP5036 do not have any integrated pattern so that animations need to be controlled by user program. Bank function let user control several channels in one command having the same behavior, to lighten some load of controller. But basically, the controller need to send commands real time to achieve patterns.
We have some device with engine function, like LP5569, which can run patterns with simple commands. But this function have not been defined into high-channel-number device yet. How much RGB LEDs and output current you need for your application?
