Part Number: TPS650864
Other Parts Discussed in Thread: TPS544C25
Hi
I'm referring TPS608640 Power Map Example of the datasheet.
In this example, TPS544C25 is used for VCCINT and PGOOD is connected to CTL4.
Where should we pull up PGOOD of TPS544C25?
VIH of CTLx is 0.85V (min), so it is impossible to connect PGOOD to output of TPS544C25.
Can I use LDO3P3 or do you have recommendation?
BestRegards
