TPS7A47: Changing Vout on the fly
Expert 4455 points
Part Number: TPS7A47
Hi LDO team,
Can the voltage selector pins & Vout of the TPS7A4700RGWR be changed dynamically?
Or is the voltage set only at power up? Is there any danger using this chip like this?
From the functional block diagram in the DS (anlog circuit for voltage setting), I would assume it's ok to adjust Vout on the fly but wanted to double-check.
Thanks & BR,
KF
