Does the SPICE model for LMR36503 support the inverting buck-boost topology?
Thanks, Steve
Thanks, Steve
Hi Antenna,
Yes, I can't think of any reason why you can't.
Please refer to the attached app note for inverting buck-boost topology.
2477.Working with inverting buck-boost converters.pdf
Hope this helps!
Please let me know if you have more questions. And otherwise please close the thread if you think your question has been answered. Thanks!
Ankit Gupta
Application Engineer
Most buck regulator models don't work in IBB; there are internal nodes tied in such a way as to break when configured that way.
Usually in a model works for inverting, the name of the model will say so, for instance the LM36015 has a model explicitely calling out inverting.
I didn't see an inverting model for the LMR36503.
Thanks, Steve
Hello Antenna,
Please email me with your request at a-gupta1@ti.com , I will get you connected with an Application Engineer responsible for this part.
He might have the model or maybe in the process of building it.
Please close this thread here, so that TI won't keep monitoring this thread on two separate platforms. Thanks!
Ankit Gupta
