BQ40Z80: BQ40Z80: bq40z80 communicate failed issue
Part Number: BQ40Z80
Hello TI support team,
I think We have similar problem to described in this topic (https://e2e.ti.com/support/power-management/f/196/t/897047
  • I don't know why the full mesage didn't appear, so this is it ones again:
    I think We have similar problem to described in this topic (https://e2e.ti.com/support/power-management/f/196/t/897047). After reset / wacking-up from shutdown / FW execution after programming, the bq40z80 seems like doing multiple resets, OperationStatus()INIT is set and multiple communication faults occur.
    I see, that this issue is solved, can you, please, share what was issue/solution in this case?
  • Hi Aleh,
    Is the lifetimes enabled?  If so, try disabling it and see if this issue goes away.
    Andy
  • Hello Andy,
    no, unfortunately disabling lifetimes did not solved my issue, the problem is still there.
    Aleh
  • Hi Aleh,
    How about the DSG and CHG FETs?  Do they turn on and off repeatedly? Thanks.
    Andy
  • Hello Andy,
    correct, if PRES pin is active, the CHG and DSG FETs turn on and off repeatedly as well.
    Setting FET_EN 0 do not solve the issue.
    Aleh
  • We do some tests on our side, and here is what we find out:
    1) The described above strange behavior is dependent of Cell Temperature, measured by bq40z80 IC. Please found in attachment the logged wrong behavior after single reset [NOK.log]. Additionally, for comparison there is OK.log, when wrong behavior didn't occur and COFIGURATION.gg.csv - the Data Memory content for both cases.
    The difference for both OK / NOK cases was only cell temperature simulated by potentiometer.
    2) Additionaly we found out, that temperature, when mentioned above wrong behavior occur is influenced by Data Memory setting, but we cannot identify how exactly.
    3) Turning off the 7s cell measurement completely eliminates wrong behavior.
    4) There is no difference, what is the source of measurement of Cell Temperature - in case if external NTC is turned off and the internal bq40z80 temperature is setted up as Cell Temperature source, the wrong behavior still occurs.
    5) The voltage of cells influence the occurrence of wrong behavior, but we cannot identify how exactly.
    For now its looks like there is some error in bq40z80 initialization sequence, which leads to described above wrong behavior.
    Fri May 29 11:02:12 CEST 2020
    Device Version Info = 4800_0_04
    BQZ Device Name = bq40z80
    BQZ Firmware Version = V0_04_BLD0005
    Design Capacity = 4400
    Design Voltage = 14400
    Specification Info = 0x0031
    Manufacturer Date = 1980-1-1
    Serial Number = 0x0001
    Manufacturer Name = Texas Instruments
    Device Chemistry = LION
    Sample,DateTime,ElapsedTime,ManufAccess,RemCapAlarm,RemTimeAlarm,BattMode,@Rate(@),@TimeFull,@TimeEmpty,@RateOK,Temperature,Voltage,Current,AvgCurr,MaxErr,RSOC,ASOC,RemCap,FullChgCap,RunTimeEmty,AvgTimeEmty,AvgTimeFull,ChgCurr,ChgVolt,BattStat,CycleCnt,MaxTurboPwr,SusTurboPwr,MaxTurboCurr,SusTurboCurr,SoH,OpStatA,OpStatB,TempRange,ChgStat,GaugeStat,ITStat,MfgStat,SafetyAlertAB,SafetyStatAB,SafetyAlertCD,SafetyStatCD,PFAlertAB,PFStatAB,PFAlertCD,PFStatCD,CellVolt1,CellVolt2,CellVolt3,CellVolt4,CellVolt5,CellVolt6,CellVolt7,vBAT,vPACK,CellCurr1,CellCurr2,CellCurr3,CellCurr4,CellCurr5,CellCurr6,CellCurr7,CellPower1,CellPower2,CellPower3,CellPower4,CellPower5,CellPower6,CellPower7,Power,AvgPow,IntTemp,TS1Temp,TS2Temp,TS3Temp,TS4Temp,CellTemp,FETTemp,GaugeTemp,FltRemQ,FltRemE,FltFullChgQ,FltFullChgE,NoLoadRemCap,TrueRemQ,TrueRemE,InitialQ,InitialE,TrueFullChgQ,TrueFullChgE,T_sim,T_ambient,RaScale1,RaScale2,RaScale3,RaScale4,RaScale5,RaScale6,RaScale7,CompRes1,CompRes2,CompRes3,CompRes4,CompRes5,CompRes6,CompRes7,PackGrid,LStatus,CellGrid1,CellGrid2,CellGrid3,CellGrid4,CellGrid5,CellGrid6,CellGrid7,StateTime,DOD0_1,DOD0_2,DOD0_3,DOD0_4,DOD0_5,DOD0_6,DOD0_7,DOD0 Passed Q,DOD0 Passed E,DOD0 Time,DODEOC_1,DODEOC_2,DODEOC_3,DODEOC_4,DODEOC_5,DODEOC_6,DODEOC_7,QMax1,QMax2,QMax3,QMax4,QMax5,QMax6,QMax7,QMaxDOD0_1,QMaxDOD0_2,QMaxDOD0_3,QMaxDOD0_4,QMaxDOD0_5,QMaxDOD0_6,QMaxDOD0_7,QMaxPassedQ,QMaxTime,Tk,Ta,RawDOD_1,RawDOD_2,RawDOD_3,RawDOD_4,RawDOD_5,RawDOD_6,RawDOD_7,CBTime1,CBTime2,CBTime3,CBTime4,CBTime5,CBTime6,CBTime7,CBDOD_1,CBDOD_2,CBDOD_3,CBDOD_4,CBDOD_5,CBDOD_6,CBDOD_7,CBTotalDODChg,SOH_FC_Q,SOH_FC_E,LogRowTime(ms),LogStatus
    1,2020-05-29 11:02:13,1.001,0x6181,300,10,0x6081,0,65535,65535,1,42.2,25403,0,0,100,8,4,150,1925,65535,65535,65535,0,0,0x02C0,0,-29799,-19518,-14190,-8800,91,0x6181,0x0000,0x20,0x0014,0xD0,0x0004,,,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.6,42.4,24.0,-273.2,-273.2,42.4,24.0,42.4,0,0,0,0,0,0,0,0,0,0,0,-273.2,42.4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,0,0,0,0,0,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1242,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\OK.log.err
    2,2020-05-29 11:02:14,2.259,0x6101,300,10,0x6081,0,0,0,0,42.3,25416,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x20,0x0014,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3593,3595,3595,3595,3595,3844,25413,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.7,42.2,23.9,-273.2,-273.2,42.2,23.9,42.4,0,0,0,0,0,0,0,0,0,0,0,-273.2,42.4,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1188,SUCCESS
    3,2020-05-29 11:02:16,3.467,0x6101,300,10,0x6081,0,0,0,0,42.2,25413,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3593,3595,3595,3595,3595,3848,25417,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.9,42.2,23.9,-273.2,-273.2,42.2,23.9,42.2,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1199,SUCCESS
    4,2020-05-29 11:02:17,5.072,0x6101,300,10,0x6081,0,65535,65535,1,42.2,25412,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29789,-19517,-14185,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3592,3592,3591,3850,25402,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.7,42.3,24.0,-273.2,-273.2,42.3,24.0,42.3,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1205,SUCCESS
    5,2020-05-29 11:02:18,6.294,0x6101,300,10,0x6081,0,65535,65535,1,42.3,25403,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29789,-19517,-14185,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3592,3592,3592,3850,25402,5,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.6,42.4,23.9,-273.2,-273.2,42.4,23.9,42.4,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1188,SUCCESS
    6,2020-05-29 11:02:20,7.497,0x6101,300,10,0x6081,0,65535,65535,1,42.4,25403,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29807,-19518,-14194,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3595,3591,3592,3592,3593,3592,3849,25402,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.6,42.4,24.0,-273.2,-273.2,42.4,24.0,42.4,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1170,SUCCESS
    7,2020-05-29 11:02:21,9.071,0x6101,300,10,0x6081,0,65535,65535,1,42.3,25402,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29807,-19518,-14194,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3591,3592,3592,3849,25402,5,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.5,42.4,23.9,-273.2,-273.2,42.4,24.0,42.4,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,6,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1205,SUCCESS
    8,2020-05-29 11:02:22,10.294,0x6101,300,10,0x6081,0,65535,65535,1,42.4,25403,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29807,-19518,-14194,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3592,3592,3592,3850,25402,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.5,42.4,24.0,-273.2,-273.2,42.4,24.0,42.4,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,7,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1183,SUCCESS
    9,2020-05-29 11:02:24,11.492,0x6101,300,10,0x6081,0,65535,65535,1,42.4,25402,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29807,-19518,-14194,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3595,3590,3592,3592,3593,3592,3850,25403,6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.4,42.4,24.0,-273.2,-273.2,42.4,24.0,42.4,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,8,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1174,SUCCESS
    10,2020-05-29 11:02:25,13.071,0x6101,300,10,0x6081,0,65535,65535,1,42.4,25403,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29807,-19518,-14194,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3592,3592,3592,3850,25403,8,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.4,42.4,24.0,-273.2,-273.2,42.4,24.0,42.4,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,10,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1174,SUCCESS
    11,2020-05-29 11:02:26,14.261,0x6101,300,10,0x6081,0,65535,65535,1,42.4,25402,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29807,-19518,-14194,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3592,3592,3592,3850,25402,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.4,42.2,24.0,-273.2,-273.2,42.4,24.0,42.4,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,11,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1170,SUCCESS
    12,2020-05-29 11:02:28,15.458,0x6101,300,10,0x6081,0,65535,65535,1,42.2,25402,0,0,100,8,4,151,1926,65535,65535,65535,0,0,0x02C0,0,-29807,-19518,-14194,-8800,91,0x6101,0x0000,0x20,0x0014,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3590,3592,3592,3593,3592,3849,25404,6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.5,42.4,24.0,-273.2,-273.2,42.4,24.0,42.4,151,355,1926,5204,217,151,355,1775,4849,1926,5204,42.4,42.2,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,12,15564,15576,15568,15570,15570,15570,7776,0,0,0,1168,1168,1168,1168,1168,1168,1168,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15564,15576,15568,15570,15570,15570,7776,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,3999,10517,1209,SUCCESS
    Fri May 29 11:04:54 CEST 2020
    1,2020-05-29 11:04:55,1.001,0x6181,300,10,0x6081,0,65535,65535,1,1.7,25403,,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x00,0x0000,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3592,3594,3594,3594,3594,3845,25411,6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.5,1.4,24.2,-273.2,-273.2,1.7,24.2,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,0,0,15592,15592,15592,15592,7520,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1242,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    2,2020-05-29 11:04:56,2.261,0x6101,300,10,0x6081,0,0,0,0,1.4,25411,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3592,3595,3595,3595,3594,3843,25409,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.9,1.6,24.0,-273.2,-273.2,1.6,24.0,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15596,15592,15592,15592,15592,7520,0,0,0,1744,1744,1744,1744,1744,1744,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15596,15592,15592,15592,15592,7520,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1186,SUCCESS
    3,2020-05-29 11:04:58,4.091,0x6101,300,10,0x6081,0,0,0,0,1.7,25412,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3593,3594,3595,3594,3594,3849,25416,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.9,1.4,24.0,-273.2,-273.2,1.5,24.0,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15596,15592,15592,15592,15592,7504,0,0,0,1744,1744,1744,1744,1744,1744,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15596,15592,15592,15592,15592,7504,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1183,SUCCESS
    4,2020-05-29 11:04:59,5.290,0x6101,300,10,0x6081,0,0,0,0,1.4,25414,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,,0x0100,0x00,0x0000,0x00,0x0000,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3592,3592,3592,3849,25402,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.9,1.6,24.1,-273.2,-273.2,1.6,24.1,1.6,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,0,0,0,0,0,15592,7584,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1235,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    5,2020-05-29 11:05:00,6.540,0x6101,300,10,0x6081,0,0,0,0,1.5,25412,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3593,3594,3594,3595,3595,3847,25415,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.0,1.4,24.0,-273.2,-273.2,1.4,24.0,1.6,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.6,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15596,15592,15592,15592,15592,7584,0,0,0,1744,1744,1744,1744,1744,1744,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15596,15592,15592,15592,15592,7584,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1173,SUCCESS
    6,2020-05-29 11:05:02,8.135,0x6101,300,10,0x6081,0,0,0,0,19.8,14400,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x04,0x0002,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3593,3595,3595,3595,3594,3846,25413,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,22.9,1.6,24.0,-273.2,-273.2,1.6,24.2,1.6,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15594,15592,15592,15592,15592,7552,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1188,SUCCESS
    7,2020-05-29 11:05:03,9.342,0x6101,300,10,0x6081,0,0,0,0,1.6,25414,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3593,3595,3595,3596,3594,3846,25417,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.1,1.4,24.0,-273.2,-273.2,1.4,24.0,1.6,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.6,1000,1000,1000,1000,,,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,0.0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1247,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    8,2020-05-29 11:05:04,10.609,0x6101,300,10,0x6081,0,0,0,0,1.6,25402,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3593,3595,3595,3595,3594,3848,25418,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.0,1.4,24.0,-273.2,-273.2,1.4,24.0,1.6,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.6,0,0,0,0,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15584,15596,15588,15592,15592,15592,7616,0,0,0,0,0,0,0,0,0,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15584,15596,15588,15592,15592,15592,7616,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1167,SUCCESS
    9,2020-05-29 11:05:06,12.183,0x6101,300,10,0x6081,0,0,0,0,1.4,25417,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,,0,0,0,0x6101,0x0100,0x00,0x0000,0x00,0x0000,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3592,3592,3592,3848,25401,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.0,1.7,24.2,-273.2,-273.2,1.7,24.2,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,0,0,0,0,0,15592,7616,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1203,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    10,2020-05-29 11:05:07,13.402,0x6101,300,10,0x6081,0,0,0,0,1.6,25412,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3593,3595,3594,3595,3594,3843,25411,8,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.0,1.6,24.0,-273.2,-273.2,1.6,24.0,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15596,15592,15592,15592,15592,7616,0,0,0,1744,1744,1744,1744,1744,1744,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15596,15592,15592,15592,15592,7616,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1171,SUCCESS
    11,2020-05-29 11:05:08,14.591,0x6101,300,10,0x6081,0,0,0,0,1.6,25415,0,0,100,0,0,0,4400,,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x00,0x0000,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3590,3592,3592,3594,3594,3848,25407,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.0,1.4,24.2,-273.2,-273.2,1.6,24.2,1.6,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,0,0,0,15592,15592,15592,7392,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1201,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    12,2020-05-29 11:05:10,16.197,0x6101,300,10,0x6081,0,0,0,0,1.4,25415,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3593,3595,3595,3595,3595,3843,25412,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.2,1.4,24.0,-273.2,-273.2,1.4,24.0,1.6,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.6,1000,1000,1000,1000,,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,0.0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1236,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    13,2020-05-29 11:05:11,17.449,0x6101,300,10,0x6081,0,0,0,0,1.6,25402,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3593,3595,3594,3595,3594,3850,25416,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.1,1.4,24.1,-273.2,-273.2,1.4,24.1,1.6,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.6,0,0,0,0,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15596,15588,15592,15592,15592,7584,0,0,0,0,0,0,0,0,0,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15596,15588,15592,15592,15592,7584,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1172,SUCCESS
    14,2020-05-29 11:05:12,18.636,0x6101,300,10,0x6081,0,0,0,0,1.4,25416,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3593,3595,3595,3595,3594,3845,25412,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,,,24.1,-273.2,-273.2,19.8,-273.2,-273.2,0,0,0,0,0,0,0,0,0,0,0,-273.2,-273.2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1249,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    15,2020-05-29 11:05:14,20.291,0x6101,300,10,0x6081,0,0,0,0,1.6,25411,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3593,3594,3595,3595,3594,3842,25409,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.1,1.4,24.0,-273.2,-273.2,1.5,24.0,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15596,15592,15592,15592,15592,7552,0,0,0,1744,1744,1744,1744,1744,1744,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15596,15592,15592,15592,15592,7552,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1187,SUCCESS
    16,2020-05-29 11:05:15,21.493,0x6101,300,10,0x6081,0,0,0,0,1.4,25412,0,0,100,0,,,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x00,0x0000,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3592,3594,3594,3594,3594,3848,25413,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.1,1.4,24.1,-273.2,-273.2,1.7,24.1,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,0,0,0,15592,15592,15592,7552,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1205,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    17,2020-05-29 11:05:17,22.715,0x6101,300,10,0x6081,0,0,0,0,1.4,25411,-3,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3593,3595,3594,3595,3594,3846,25412,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.2,1.4,24.0,-273.2,-273.2,1.4,24.0,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15596,15592,15592,15592,15592,7552,0,0,0,1744,1744,1744,1744,1744,1744,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15596,15592,15592,15592,15592,7552,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1172,SUCCESS
    18,2020-05-29 11:05:18,24.311,0x6101,300,10,0x6081,0,0,0,0,1.7,25406,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3593,3595,3594,3595,3594,3848,25416,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.1,1.4,24.0,-273.2,-273.2,1.4,24.0,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,0,0,0,0,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15596,15592,15592,15592,15592,7456,0,0,0,0,0,0,0,0,0,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15596,15592,15592,15592,15592,7456,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1169,SUCCESS
    19,2020-05-29 11:05:19,25.496,0x6101,300,10,0x6081,0,0,0,0,1.4,25411,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0xD0,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3593,3595,3595,3595,3595,3847,25415,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,,1.7,24.1,-273.2,-273.2,19.8,-273.2,-273.2,0,0,0,0,0,0,0,0,0,0,0,-273.2,-273.2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1216,ERROR : Please check C:\Users\ahalauko\Desktop\TI1946\NOK.log.err
    20,2020-05-29 11:05:21,26.729,0x6101,300,10,0x6081,0,0,0,0,1.7,25413,0,0,100,0,0,0,4400,0,0,0,0,0,0x0040,0,0,0,0,0,0,0x6101,0x0100,0x02,0x0004,0x50,0x0004,0x8000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3593,3595,3594,3595,3594,3847,25415,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,23.1,1.4,24.0,-273.2,-273.2,1.4,24.0,1.7,0,0,0,0,0,0,0,0,0,0,0,-273.2,1.7,1000,1000,1000,1000,1000,1000,1000,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15586,15594,15592,15592,15592,15592,7584,0,0,0,0,0,0,1744,1744,1744,1744,4400,4400,4400,4400,4400,4400,4400,0,0,0,0,0,0,0,0,0,1.0,1000,15586,15594,15592,15592,15592,15592,7584,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1172,SUCCESS
    CONFIGURATION.gg.csv
    7450.CONFIGURATION.gg.csv
  • Hi Aleh,
    I will take a look at the log files.
    Could you adjust the stack voltage and see if it happens in a particular voltage?
    I see Vincenzo already sent me an email regarding the same issue.  I will work with him to provide some feedback as soon as possible.
    Andy
    as i wrote above, the voltage influence the wrong behavior, but we are not sure how exactly.
    I was able to observe this behavior on the same configuration as above and the wrong behavior occur for 3100 mV / cell, 3600 mV/ cell and 3900 mV / cell.
    There was no wrong behavior on 4000 mV/cell.
    Did you look at attached settings logs? Do you have any conclusions to share?  The topic is urgent for us, and we really need to know what is the reason here?
    Aleh
  • Hi Aleh,
    I'm working with Vincenzo on this issue. This issue will be taken care of offline.
    Andy
