UCC27524: UCC27524DGNR
Part Number: UCC27524
Other Parts Discussed in Thread: UCC27424
Can UCC27524 drive both the outputs simultaneously?
Datasheet says that IC can avoid shoot through..
  • Hi Ansul,
    If some resistance on OUTx pins, you may parallel channels for higher drive current as shown below.
    The diagram below uses UCC27424 block diagram but the concept is applicable to UCC27524 as well.
    -Mamadou
