The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
LM61435-Q1: Thermal shutdown indication
Part Number: LM61435-Q1
Hi,  Is there a signal we can use to tell a control system that the part has shutdown due to over temperature-  could the power good tells us anything- I note the the internal regulator is kept alive?
  • Hello Ajay,
    Power Good is an indication of VOUT going out of regulation, and that can be because of thermal shutdown, hiccup, or any other fault scenario.
    There is no particular one signal available indicating the thermal shutdown specifically, but I would recommend using the power good signal in your control system as an indication of a fault scenario.
    I hope this helps!
    And please close the thread if you think your question has been answered. Thanks!
    Ankit Gupta
    Application Engineer
  • HI Ankit, thanks for this- I could not see anywhere in the data sheet that specifically says thermal shutdown pulls PG to ground- but if thi sis the case that is great.
  • Hi Ajay,
    It is actually mentioned in the datasheet in section "8.3.5 PGOOD Output Operation". Please see the screenshot below:
    I hope this helps!
    Please close the thread if you think your question has been answered. Thanks!
    Ankit Gupta
