BQ2060A: Is there any problem when I connect VCELL4 firstly,then connect VCELL3 ?
Part Number: BQ2060A
Other Parts Discussed in Thread: BQ2060
Dear all
      If I firstly connect the VCELL4 pin to battery, the connect VCELL3 pin to battery,  the BQ2060A device will be damaged ?
  • First of all, bq2060 is quite old and I would suggest you use newer devices like the bq4050.
    Regarding your questions, I guess the device should be probably still fine. Have you seen any issue after you did so?
    However, I would still suggest you follow the instructions in the EVM user's guide to connect the cells.
    Andy
